Configures the LLDP port to advertise or not advertise its maximum frame size to its neighbors.
| all | Specifies all ports on the switch. |
| port_list | Specifies one or more ports or slots and ports. |
| advertise | Specifies to send the information to neighbors. |
| no-advertise | Specifies not to send the information to neighbors. |
No advertise.
When jumbo frames are not enabled on the specified port, the TLV reports a value of 1518 once you configure it to advertise. If jumbo frames are enabled, the TLV inserts the configured value for the jumbo frames.
The following command configures ports 1:12 and 1:13 to advertise the maximum frame size to neighbors:
configure lldp ports 1:12 - 1:13 advertise vendor-specific dot3 max-frame-size
